Campus
Oct 07, 2015Luminary
SMB Plus probably destroyed my 6.2.4 installation
Hi, two days ago I tried the SMB Plus addon and after testing it I uninstalled. This uninstall came up with an error message. I ignored this error. Then I had to restart the machine and now my sa...
Campus
Ok, found the right page to reinstall 6.2.4 and after that it was working again. The SMB Plus needs to be fixed anyway.
kohdee
Oct 08, 2015NETGEAR Expert
SMB Plus makes changes to an overrides file, so its functionality is very limited in the grand scheme of things. On uninstall of SMB Plus, the overrides file is not manipulated. On OS Reinstall, the overrides file is not touched, so I don't believe this was your problem.
- CampusOct 08, 2015Luminary
Thanks for your explanation. Could you please point me to the override file so I can manually remove it from the machine?
Best,
Campus
