Scouser
Dec 02, 2011Aspirant
So I installed the Java addon. But where is it?
Title says it all.
- ScouserAspirantMainStore:/mnt/buildenv# debootstrap --arch i386 etch $BUILDENV http://archive.debian.org/backports.org
I: Retrieving Release
E: Failed getting release file http://archive.debian.org/backports.org/dists/etch/Release
Its always tacking that damn "dists/etch/Release" on the end and it dont exist. Its in http://archive.debian.org/backports.org/dists/etch-backports/ - WhoCares_MentorWhy do you want to get backports anyway? Just use etch and if need be add the backports repo later.
So the correct line would be: debootstrap --arch i386 etch $BUILDENV http://archive.debian.org/debian
-Stefan - ScouserAspirantYup that did it. Woo hoo!
Thanks mega heaps Stefan. I'll go have a play ;) - ScouserAspirantHi Stefan,
I have just got back to building my dev environment. Been busy with a load of hassle at home.... :(
So I got a virgin buildenv using debootstrap. But now stuck with configuring the new chroot environment.
What should I have in my sources.list file?
The devbuild wefixit page gives examples referring to lenny.
My current sources.list looks like this. But it does fails.deb http://archive.debian.org/debian etch main
deb http://archive.debian.org/debian etch non-free
deb http://archive.debian.org/debian-backports etch-backports main non-free
This gives the following:W: GPG error: http://archive.debian.org etch-backports Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY EA8E8B2116BA136C
W: You may want to run apt-get update to correct these problems
TIA - WhoCares_MentorYou need to install the updated GPG signatures from etch-backports manually. Download and install using dpkg -i ...
-Stefan - ScouserAspirantSorry Stefan. As I said, I am really an old time Unix hack. Getting around Linux is a challenge for me but I am competent once I understand the gist of things. Can you be a bit more specific for an old dog ;) .... dpkg -i ?
- ScouserAspirantOh craps! I saw this viewtopic.php?f=35&t=59430&p=334004&hilit=GPG#p334004
Stefan, does this mean I am hosed? - WhoCares_MentorNo because your problem is with the back ports repo for which a GPG is available whereas the problem in the other thread is with Netgear's 4.2.19 repo for which no valid key is available ;) So you just need to download the Debian Archive Keyring and install the file using "dpkg -i <filename>"
-Stefan - ScouserAspirantStefan. Thanks mate. Really appreciate it. I know I keep saying it but I do.
So, I now have my dev env setup. Downloaded the ReadyNAS GPL resources (as an aged Unix hack Iam blown away that these are even public!), installed gcc, gdb, make etc and I have even run configure/make in a ffmpeg to test it. Runs great. So, to start with, serviio has had problems with ffmpeg and there is a patch just ab out to com out for fixing mkv files on certain dst runs. I will have that in the next day or so. But right now, things are looking sweet. I guess I will figure out which packages I am missing as I go along. e.g., I installed gcc and the libs and all and just presumed "make" would come with it but it didnt so a quick apt-get sorted that.
Just compiled strace.....woo hoo!
briliant! thanks again. - WhoCares_MentorThe thing is that you probably can't use the ffmpeg as supplied by Netgear because this one has been stripped down a lot. You may be fine by manually configuring the sources as you did but rather than doing this I'd advise to use the Debian build tools like 'dpkg-buildpackage' or 'rebuild' to build the stuff. You should be able to find newer releases of ffmpeg in the Debian repos for Lenny/Squeeze/Sid. Actually I already built one myself for the KMotion project so I know it's doable but it's going to be tough work ;)
-Stefan
