Suncoaster
Aug 25, 2015Aspirant
Stuck in Setup Wizard
This is the error I get when I attempt to finish the setup of this application. What do I need to do to fix this problem.
mdgm-ntgr
Aug 25, 2015NETGEAR Employee Retired
Which firmware version are you running?
Which version of the app do you have installed?
- SuncoasterAug 25, 2015Aspirant
Firmware 6.2.5
App 2.0.5
- mdgm-ntgrAug 26, 2015NETGEAR Employee Retired
Have you tried multiple different web browsers?
- SuncoasterAug 26, 2015Aspirant
mdgm wrote:Have you tried multiple different web browsers?
I have tried both Firefox amd Chrome. These are the only two browsers I have on my Linux Mint 17.2 system
- JennCAug 26, 2015NETGEAR Employee Retired
Hi Suncoaster,
Have you tried also removing the app then re-adding it?
Do you also get the same problem when installing other apps?
JennC wrote:Hi Suncoaster,
The only other app I have installed is the Antivirus Plus and after your help it is working fine. Yes I have tried several times and it always fails at the same place. The log says the app installed correctly.
Regards
