Suncoaster
Aug 25, 2015Aspirant
Stuck in Setup Wizard
This is the error I get when I attempt to finish the setup of this application. What do I need to do to fix this problem.
mdgm-ntgr
Aug 25, 2015NETGEAR Employee Retired
Which firmware version are you running?
Which version of the app do you have installed?
Suncoaster
Firmware 6.2.5
App 2.0.5
- mdgm-ntgrAug 26, 2015NETGEAR Employee Retired
Have you tried multiple different web browsers?
- SuncoasterAug 26, 2015Aspirant
mdgm wrote:Have you tried multiple different web browsers?
I have tried both Firefox amd Chrome. These are the only two browsers I have on my Linux Mint 17.2 system
- JennCAug 26, 2015NETGEAR Employee Retired
Hi Suncoaster,
Have you tried also removing the app then re-adding it?
Do you also get the same problem when installing other apps?
JennC wrote:Hi Suncoaster,
The only other app I have installed is the Antivirus Plus and after your help it is working fine. Yes I have tried several times and it always fails at the same place. The log says the app installed correctly.
Regards
Hi Suncoaster,
Please turn off AntiVirus plus then try launching the ReadyNAS Photos 2 again. Please also try adding another P2P app like Qbittorent client and see if the same problem or if it will launch with the AntirVirus plus running or with the ReadyNAS Photos 2.
