Suncoaster
Aug 25, 2015Aspirant
Stuck in Setup Wizard
This is the error I get when I attempt to finish the setup of this application. What do I need to do to fix this problem.
mdgm-ntgr
Aug 28, 2015NETGEAR Employee Retired
Can you verify if UPNP is enabled and working properly?
Could you also test as an alternative port forwarding the port for Photos II?
Suncoaster
Aug 28, 2015Aspirant
I can confirm that UPNP is enabled but how can I test if it working? Also how can I change the port used in the app. By default the app chose 8086 as the port and I cannot change it. Are there any installation instructions available for this app that may help me out.
Regards
- Retired_MemberSep 04, 2015
Hello,
I have the exact same problem than Suncoster, same error message during the Setup Wizard.
I on a RN516, firmware 6.2.4 and version 2.0.5 of ReadyNAS Photos 2.
I tried from Chrome and Firefox on Mac it didn't work.
Thank you in advance for the help.
Best!
- matmarSep 18, 2015Guide
Me too RNNAS516 6.4 Beta 5
exact same issue.
I also have a RNDU4000 with which no issue on the same network.
Thanks in advance
