Lionelv00
Jul 24, 2015Aspirant
Subversion addon - connection refused
Hi all, readynas ultra 2 I've installed the subversion addon from rnxtras. Now when I try to checkout I get connection refused. Here are the steps I followed: On the readnas: NetgearNAS:...
- Aug 16, 2015
Sorry for the late reply, still trying to get used to the new "forums".
Actually, you were already close. You created the SVN repo correctly but the correct command to checkout a repo from the ReadyNAS would be
svn checkout https://192.168.1.100/svn/SVNTest
Two things to note here: For accessing the Repo you have to either use the HTTP or the HTTPS protocol, not SVN. And for the path to the repo you habe to prefix the repo's name with "/svn/".
When pushing changes to the ReadyNAS you'll have to authenticate using a valid username/password combination as defined on the ReadyNAS.
-Stefan
WhoCares_
Aug 16, 2015Mentor
-Stefan
Lionelv00
Aug 20, 2015Aspirant
Thanks for the response, but still no joy :(
This is the error:
svn: E170013: Unable to connect to a repository at URL 'http://192.168.1.100/svn/SVNTest' svn: E120108: Error running context: The server unexpectedly closed the connection.
Are there decent logs anywhere showing why?
