c2h5oh
Jan 14, 2017Initiate
Sync with Amazon Cloud Drive attempts to upload files larger than accepted by the service, deauths
Amazon Cloud Drive has a limit of 50GB per file. Sync will happily attempt to upload files over that limit, fail and gets deauthorized for the service. I don't know if Amazon actually revokes the au...
FramerV
Jan 16, 2017NETGEAR Employee Retired
Hi c2h5oh,
Welcome to the community.
I cannot really tell, I may need to ask some of my colleagues about it.
May I ask what ReadyNAS model and firmware version are you using?
c2h5oh
Jan 17, 2017Initiate
Tested on Ultra 4 running 6.6.0 and 6.6.1
- FramerVJan 18, 2017NETGEAR Employee Retired
Hi c2h5oh,
I will try and inquire about your case for now.
- silencioMar 28, 2017Aspirant
Is there any movement on this issue?
I'm having the same problems - the ReadyNAS attempts to continually upload files greater than 50GB resulting in the sync just getting stuck. Ideally, I guess, these files should be split into parts using SPLIT or something like that when uploaded to amazon, but this is obviously a bit complex, so simply ignoring them and flagging up the problem somewhere would be a reasonable solution (sending an email to the administrator?)
- mdgm-ntgrSep 05, 2017NETGEAR Employee Retired
Do you still have this issue?
- silencioSep 05, 2017AspirantAs far as I know. I have been splitting files manually top cope with the problem so I haven't had it recently. I could try again with a large file - but as far as I'm aware nothing has changed, is there any reason to believe it would be working now?
