c2h5oh
Jan 14, 2017Initiate
Sync with Amazon Cloud Drive attempts to upload files larger than accepted by the service, deauths
Amazon Cloud Drive has a limit of 50GB per file. Sync will happily attempt to upload files over that limit, fail and gets deauthorized for the service. I don't know if Amazon actually revokes the au...
c2h5oh
Jan 17, 2017Initiate
Tested on Ultra 4 running 6.6.0 and 6.6.1
FramerV
Jan 18, 2017NETGEAR Employee Retired
Hi c2h5oh,
I will try and inquire about your case for now.
- silencioMar 28, 2017Aspirant
Is there any movement on this issue?
I'm having the same problems - the ReadyNAS attempts to continually upload files greater than 50GB resulting in the sync just getting stuck. Ideally, I guess, these files should be split into parts using SPLIT or something like that when uploaded to amazon, but this is obviously a bit complex, so simply ignoring them and flagging up the problem somewhere would be a reasonable solution (sending an email to the administrator?)
