Retired_Member
Sep 21, 2014TeamSpeak3 autostart + frontend (webadmin)
HI, CHECK THE LAST POST DIRECTLY, THANKS. viewtopic.php?f=153&t=77743#p438777
mdgm-ntgr
Sep 21, 2014NETGEAR Employee Retired
Also if you want it to be started like an app you would need it to be started via systemd.
I would suggest you have a look at the SDK on apps.readynas.com
