Retired_Member
Sep 21, 2014TeamSpeak3 autostart + frontend (webadmin)
HI, CHECK THE LAST POST DIRECTLY, THANKS. viewtopic.php?f=153&t=77743#p438777
Retired_Member
Nov 03, 2014I have discovered that some of other application's files are also located in "./apps/.freeapps" directory, but when i have copied "config.xml" and "logo.png" into new "teamspeak3" directory, it didnt worked. Logo ("logo.png") is still not showing up in frontend (webadmin). Also after NAS restart, it didn't worked. Folder "teamspeak3" was located also in "./data/.apps/.freeapps: where i have checked this. Could someone help a little?
