secret_rivals
Sep 16, 2009Aspirant
Torrentflux stopped connecting to torrents
I have been using Torrentflux for months with no problems at all. The other week my torrents stopped connecting to the trackers (new ones and existing ones). The error message I get is warning - crypto library not installed. I have googled this error and found the resolution for linux desktop users http://www.torrentflux.com/forum/index.php?topic=3715.0 - they need to install python-crypto, although I am usure how to get this onto the ReadyNAS.
I have also tried disabling the Only allow encrypted connections and the Stealth crypto options from within Torrentflux's settings and this doesn't help.
Does anyone know how to get python-crypto onto the ReadyNAS or is anyone else aware of an alternate fix for this?
Update: this only appears to be happening on newly downloaded torrent files. Is anyone else having this problem?
- super_poussinVirtuosoI will check
did you try transmission ? transmission is up to date and more comaptible with last trackers version - secret_rivalsAspirantHi, I had the problem with Transmission first, then tried Torrentflux.
- secret_rivalsAspirantThis problem looks like it is a problem with trackers from ilovetorrents.com other trackers I have tried appear to be OK.
- secret_rivalsAspirantDoes anyone know how to update python-crypto onto the ReadyNAS. I have the Apt plugin installed and I have read on the Torrentflux forums to update the python-crypto files with apt-get install python-crypto http://www.torrentflux.com/forum/index.php?topic=4040.msg22047. I am hesitant in running this apt get command because of this warning on the ReadyNAS webste: http://www.readynas.com/?p=145 "Please note that you can get your ReadyNAS into peril easily by overriding some of the system libraries and utilities. Do not do your development on a system you don’t have a backup of as you may end up re-installing the firmware or worse yet, doing a factory default."
super-poussin do you think I will brick my ReadyNAS if I run apt-get install python-crypto ? - x3uzAspirantFor the problem whit crypto-lib
source: http://www.linux-france.pro/2010/12/22/torrentflux-problems-crypto-library-not-installed/warning – crypto library not installed
just:cd /opt
wget http://www.amk.ca/files/python/crypto/pycrypto-2.0.1.tar.gz
tar -xzf pycrypto-2.0.1.tar.gz
cd pycrypto-2.0.1
python setup.py build
python setup.py install
Work 100% ! :wink: - HyperbitAspirantcan't install crypto 2.6
datengrab:/opt/pycrypto-2.6# python setup.py install
running install
running build
running build_py
running build_ext
running build_configure
building 'Crypto.PublicKey._fastmath' extension
cc -pthread -fno-strict-aliasing -fwrapv -Wall -Wstrict-prototypes -fPIC -std=c99 -O3 -fomit-frame-pointer -Isrc/ -I/usr/include/ -I/usr/include/python2.7 -c src/_fastmath.c -o build/temp.linux-padre-2.7/src/_fastmath.o
unable to execute cc: No such file or directory
error: command 'cc' failed with exit status 1
whats wrong?
2nd try with easy_install ends in same resultdatengrab:/c/datensammlung/pycrypto-2.6# easy_install http://pypi.python.org/packages/source/p/pycrypto/pycrypto-2.6.tar.gz#md5=88dad0a270d1fe83a39e0467a66a22bb
Downloading http://pypi.python.org/packages/source/p/pycrypto/pycrypto-2.6.tar.gz#md5=88dad0a270d1fe83a39e0467a66a22bb
Processing pycrypto-2.6.tar.gz
Running pycrypto-2.6/setup.py -q bdist_egg --dist-dir /tmp/easy_install-DUB9dV/pycrypto-2.6/egg-dist-tmp-sWHfqe
cc1: error: unrecognized option `-fwrapv'
error: Setup script exited with error: command 'cc' failed with exit status 1 - super_poussinVirtuosois gcc installed ?
if yes try this : apt-get install python-dev - HyperbitAspirant
datengrab:~# apt-get install python-dev
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
python-dev: Depends: python (< 2.4) but 2.7.3~rc2-1.1rnx2 is to be installed
E: Broken packages
doesnt work..
i takes python from the readynasxtras site
