gyves1
Jul 28, 2015Luminary
Transmission add-on for ReadyNAS
Hi,
I have installed the Transmission add-on version 3.0.0.8 from DEV "Poussin" on my ReadyNAs 312 (fw 6.2.4) but often the web UI of this add-on falls, and can't available anymore on installed port (8181 in my case)
Do you know this issue?
Where can I find a update
Yves
- gyves1LuminarySorry for my late reply, I was on summer holiday.
Yes correct, only ip works - mdgm-ntgrNETGEAR Employee Retired
Do you have any other apps installed?
Do you lose access to the web interface for other apps as well?
- gyves1Luminary
Hi,
Thank you for your reply
I have followed your suggestion by installing an another App (Qbittorent), and it's the same problem.
I have typed the ip address (with same port 8181) of my NAS, and now I can find my Transmission WebUi;
The issue doesn't come from Transmission App but from DNS from my ReadyNAS network setting or from my Netgear router, I don't know
But when I use my ReadyNAS name with port80 in IE, I can find my ReadyNas main page, like this https://my_readynas_name/ but when I use an other port number (for app) https://my_readynas_name:8181 (example for Transmission add-on) it's not working :-(
- BrianL2NETGEAR Employee Retired
Hi gyves1,
Try to uninstall the add-on and get a fresh copy here and download the x86 type. Upload it in your NAS and wait a minute for it to be installed. Check your installed add-ons, turn on or toggle the transmission add-on then launch it. The username and password is admin.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
