Deaf_Raiders1
Feb 28, 2016Aspirant
transmission duo 2.42 - working settings
Been trying all day to get this working, I keeps working for about 5mins then crashes with Connection Refused... get on my nerves now can't figure out what the issue is, Here is my settings.json (which were taking from this post https://community.netgear.com/t5/Legacy-NETGEAR-and-Partners-Add/transmission-duo-2-42-working-settings/td-p/886230)
I am still on RAIDaitor 4.1.8 if i upgrade it transmission stops working.
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 32,
"dht-enabled": false,
"download-dir": "/media/BitTorrent/",
"download-queue-enabled": true,
"download-queue-size": 3,
"encryption": 2,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/c/media/BitTorrent/Incomplete",
"incomplete-dir-enabled": true,
"lazy-bitfield-enabled": true,
"lpd-enabled": false,
"max-peers-global": 120,
"message-level": 3,
"open-file-limit": 32,
"peer-congestion-algorithm": "",
"peer-limit-global": 100,
"peer-limit-per-torrent": 30,
"peer-port": 55893,
"peer-port-random-enabled": 0,
"peer-port-random-high": 65535,
"peer-port-random-low": 1024,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": false,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"queue-stalled-enabled": false,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{d15b146a3063b3ade7d0fecaa9602218a327a8c8gOoal64v",
"rpc-port": 8181,
"rpc-url": "/transmission/",
"rpc-username": "admin",
"rpc-whitelist": "*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "/c/addons-config/Transmission/email_alert",
"seed-queue-enabled": false,
"seed-queue-size": 5,
"speed-limit-down": 400,
"speed-limit-down-enabled": false,
"speed-limit-up": 20,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 18,
"upload-slots-per-torrent": 3,
"utp-enabled": false,
"watch-dir": "/c/media/BitTorrent/sources/",
"watch-dir-enabled": 0
Please help it worked lastnight did not change anything, there was a powercut during the night.
Danny
- Deaf_Raiders1Aspirant
I can confirm if other add-ons or devices services are working fine although
- ReadyDLNA is not updating my media list on PS4,
- ReadyNAS Remote which I don't use
- File Sharing Protocols is working between iMac and Windows 7 computer
I will send you a copy of my logs when I get home maybe that will give you a good idea what is experience my issue.
Regards
Danny
This is what i get now
- BrianL2NETGEAR Employee Retired
Hi Deaf_Raiders1,
Can't see the picture from the link. Can you upload it here instead? Let's see if the app developer super_poussin could help.
Kind regards,
BrianL
NETGEAR Community Team
- Deaf_Raiders1AspirantThe status is system starting up
- Deaf_Raiders1AspirantI rebooted it. Now status is checking file system...
Hi Deaf_Raiders1,
Is it finished? If not, try to perform Skip volume check.
Kind regards,
BrianL
- Deaf_Raiders1AspirantNope still running this morning when I got up. Can't skip volume check I can't get into the browser or is there a method of button to press? I don't want to lose stuff on the NAS my final year of college work is on it but I only have some of the backup
Deaf_Raiders1 wrote:
Can't skip volume check I can't get into the browser or is there a method of button to press?It's a boot option, not a web browser option. See page 16 of your hardware manual.
http://www.readynas.com/download/documentation/HM/Duov1_NV%2Bv1_HW_en_06Dec11.pdf wrote:
For example, to perform a skip volume check, press and hold the Power button until all Disk LEDs flash once, after 5 seconds.You do want to be careful on the duo, since there is no LCD panel to prompt you. But this particular option isn't very difficult.
I don't want to lose stuff on the NAS my final year of college work is on it but I only have some of the backupOne option is to power down the NAS, and connect disk 1 to a PC. There's a freeware utility called linux reader that should be able to extract your data. http://www.diskinternals.com/linux-reader/ Don't format the disk for windows of course.
Thank you i need to buy an external hard drive to transfer the data too :)
- Deaf_Raiders1AspirantRight can't skip volume check lights still blinking. I just going back up it then factory set it
- Deaf_Raiders1AspirantI can't view any of NAS drives with the link you posted StephenB. I was looking over this forums and found one called R-Linux that picks up my drive so I have to scan it and that takes 10hours. So I will leave that running while I am at work tomorrow.
