BadButton
May 14, 2013Aspirant
Unable to get Fan Control to work!
I have a readynas ultra2 plus with OS6 installed. Howerver I am unable to get the automated fan control to work properly.
When running the pwmconfig tuturioal created by pywong I seem to get stuck and unable to properly configure the fan control. Is this the normal out put for the Ultra 2 plus when running though this tutorial? Do i have to install the drivers?
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `it87':
* ISA bus, address 0xa10
Chip `ITE IT8721F/IT8758E Super IO Sensors' (confidence: 9)
Driver `coretemp':
* Chip `Intel digital thermal sensor' (confidence: 9)
Warning: the required module it87 is not currently installed
on your system. If it is built into the kernel then it's OK.
Otherwise, check http://www.lm-sensors.org/wiki/Devices for
driver availability.
Warning: the required module coretemp is not currently installed
No modules to load, skipping modules configuration.
Unloading i2c-i801... failed
Driver `it87':
Driver `coretemp':
- BadButtonAspirant
chirpa wrote: http://www.readynas.com/forum/viewtopic.php?f=51&t=70133&p=391427&hilit=It87#p391427 ?
Im a noob at linux, but im trying. I am unable to find the coretemp.ko or i87.ko modules though. It appears that the download links may be dead just full of adds. :( Know of any other place the could be found? Thanks for your help so far! - chirpaLuminaryYes, I just tried myself, none of them work. I replied in that thread noting the issue.
- BadButtonAspirant
chirpa wrote: Yes, I just tried myself, none of them work. I replied in that thread noting the issue.
spider man poseted the files in the other thread that you refereed to. But sadly they did not work. I not sure how to proceed, are those drivers any good? are they even compatible with the Ultra 2 Plus. I tryeed installing thoes modules but i receive this error. are these files even from the same build?
insmod: can't insert 'it87.ko': invalid module format same error with coretemp - chirpaLuminaryYou'll likely have to compile them from GPL sources then.
- RoyanAspirant
Have you tried using modprobe?
http://lm-sensors.org/wiki/FAQ/Chapter2
Brgds
Royan - BadButtonAspirant
Brgds
Royan
Whats really interesting is that i did not have the high fan speed noise that other people on this forums are reporting. Its just as quite as it was on 4.2. I have just done a factory default and have only installed lm-sensors. I have tried reading it my self. It looks like the NAS found the drivers themselves without even a mod probe. However i did try modprobe regardless. The command took and i received no feedback from it. Here is a print out of my fan Speeds.
root@ULT2:/# sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +36.0°C (high = +80.0°C, crit = +100.0°C)
Core 1: +33.0°C (high = +80.0°C, crit = +100.0°C)
it8721-isa-0a10
in0: +0.00 V (min = +0.00 V, max = +0.00 V) ALARM
in1: +4.91 V (min = +0.09 V, max = +4.93 V) ALARM
in2: +0.00 V (min = +0.00 V, max = +0.00 V) ALARM
in3: +0.00 V (min = +0.00 V, max = +0.00 V)
in4: +3.28 V (min = +1.35 V, max = +1.20 V) ALARM
in5: +1.16 V (min = +0.72 V, max = +1.45 V)
in6: +11.87 V (min = +8.73 V, max = +8.99 V) ALARM
in7: +3.29 V (min = +0.34 V, max = +4.92 V)
in8: +3.26 V
fan1: 1967 RPM (min = 15 RPM)
fan2: 0 RPM (min = 10 RPM) ALARM
temp1: +0.1°C (low = -112.0°C, high = +6.0°C) ALARM sensor = thermal diode
temp2: +0.0°C (low = +41.0°C, high = -3.0°C) ALARM sensor = thermal diode
temp3: -0.1°C (low = -52.0°C, high = +79.0°C) sensor = disabled
cpu0_vid: +2.050 V
