BadButton
May 14, 2013Aspirant
Unable to get Fan Control to work!
I have a readynas ultra2 plus with OS6 installed. Howerver I am unable to get the automated fan control to work properly. When running the pwmconfig tuturioal created by pywong I seem to get stuck...
BadButton
May 16, 2013Aspirant
Royan wrote:
BadButton wrote:
insmod: can't insert 'it87.ko': invalid module format same error with coretemp
Have you tried using modprobe?
http://lm-sensors.org/wiki/FAQ/Chapter2
Brgds
Royan
Whats really interesting is that i did not have the high fan speed noise that other people on this forums are reporting. Its just as quite as it was on 4.2. I have just done a factory default and have only installed lm-sensors. I have tried reading it my self. It looks like the NAS found the drivers themselves without even a mod probe. However i did try modprobe regardless. The command took and i received no feedback from it. Here is a print out of my fan Speeds.
root@ULT2:/# sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +36.0°C (high = +80.0°C, crit = +100.0°C)
Core 1: +33.0°C (high = +80.0°C, crit = +100.0°C)
it8721-isa-0a10
in0: +0.00 V (min = +0.00 V, max = +0.00 V) ALARM
in1: +4.91 V (min = +0.09 V, max = +4.93 V) ALARM
in2: +0.00 V (min = +0.00 V, max = +0.00 V) ALARM
in3: +0.00 V (min = +0.00 V, max = +0.00 V)
in4: +3.28 V (min = +1.35 V, max = +1.20 V) ALARM
in5: +1.16 V (min = +0.72 V, max = +1.45 V)
in6: +11.87 V (min = +8.73 V, max = +8.99 V) ALARM
in7: +3.29 V (min = +0.34 V, max = +4.92 V)
in8: +3.26 V
fan1: 1967 RPM (min = 15 RPM)
fan2: 0 RPM (min = 10 RPM) ALARM
temp1: +0.1°C (low = -112.0°C, high = +6.0°C) ALARM sensor = thermal diode
temp2: +0.0°C (low = +41.0°C, high = -3.0°C) ALARM sensor = thermal diode
temp3: -0.1°C (low = -52.0°C, high = +79.0°C) sensor = disabled
cpu0_vid: +2.050 V
