xander85
Nov 09, 2015Aspirant
Uninstall SickBeard
Hi All, I am a new user to the ReadyNAS family. Recently it was suggested to me by a stanger at PAXaus to try sickbeard. So I attempted to install, seemed okay. But it refused to "switch on". Now...
JennC
Nov 10, 2015NETGEAR Employee Retired
Hello xander85,
Welcome to the community!
I've some questions to ask.
- Have you tried uninstalling it using a different web browser?
- Have you tried turning it on using a different web browser?
- What is the model number of your ReadyNAS?
xander85
Nov 10, 2015Aspirant
Yes, still the same issue, just hangs on the "Removing Application..." pop up. I have left it like this for hours once. No change.
Yes, no change. Still refuses to turn on.
ReadyNAS 104
I should also note that there is no icon on the application.
- xander85Nov 11, 2015Aspirant
The NAS shuts down every night on schedule as it keeps me awake at night.
I have rebooted it to try fix the issue. No luck.
Basically, it is stuck & I cannot remove it by any normal means.
- JennCNov 12, 2015NETGEAR Employee Retired
Hello xander85,
Please see this article and observe if you get the same problem.
If same problem, you may try ReadyNASOS 6.4.1-T29 (Beta 2).
