profeta64's avatar
profeta64
Luminary
Mar 22, 2018
Updated software for our ReadyNAS
Hi to all,   i would like to thank super_poussin for the great job done in the past in order to provide to all the tons of Apps ready to be installed. By the way, the list of the available applica...
  • kohdee's avatar
    Mar 22, 2018
    Almost all of the apps in the Apps section are made by community developers. NETGEAR does not maintain those apps and rely on the developers of their apps to keep them updated. We will commonly remove apps which are no longer compatible as we release new firmware and the developer of the package receives an e-mail to inform them of the pulling. We're reliant on app developers to use our app portal and then go through a small bit of QA before we can post them. We will approve almost any app which meets the standards listed in our SDK.
    https://github.com/ReadyNAS/sdk/wiki
ProSupport for Business
