horim80's avatar
horim80
Guide
Nov 22, 2013
Virtualbox on OS6 NAS
Hi all,
I know that it's possible to install VirtualBox on legacy x86 NAS.
What about OS6? Does anyone knows how to install VirtualBox on OS6?
Thanks.
  • Thanks for the new link mdgm!
    So here is what I needed to do first to update virtualbox for OS 6.2.3. Then follow the installation guide on page 2, just remember to remove linux-3.0.101-0.40 links and files then install linux-3.0.101-0.46
    apt-get install ncurses-dev
    cd /usr/src/linux-3.0.101-0.46/scripts/basic/
    chmod 777 fixdep
    *** You may not need 777 but I was lazy
    Now due to me doing a few unnecessary changes you may not need to do the following steps if you so try without first.
    apt-get install buid-essential
    apt-get -f install
  • I understand that some RN516s have come with VT-x enabled, mine didn't and I requested help from ReadyNas support. So far, I've been turned down cold. Has anyone figured out how to configure the bios or at least enable VT-x in the bios?
  • By the way, I want to thank the forum for providing me with a solution
        ###  Upgrading NAS to 6.4.2  ###
        ###   Upgrading VirtualBox     ###
        ###              to 5.0.16             ###
    Download to NAS /data/VirtualBox:
    http://download.virtualbox.org/virtualbox/5.0.16/
    *Oracle_VM_VirtualBox_Extension_Pack-5.0.16.vbox-extpack
    *VBoxGuestAdditions_5.0.16.iso
    *virtualbox-5.0_5.0.16-105871-Debian-wheezy_amd64.deb
    http://kb.netgear.com/app/answers/detail/a_id/2649/~/gpl-open-source-code-for-programmers
    *ReadyNASOS_V6.4.2_WW_src.zip
        ## Installation of NAS update
        Either manual or auto install ReadyNAS Update 6.4.2
        ## Cleanup
        SSH to NAS
        # ** Removing the symbolic link to the old kernel files for OS 6.2.4 (or 6.2.3)
        cd /usr/src
        rm linux-3.0.101-0.46
        # ** Removing the linux-3.0.101-0.46 directory for OS 6.2.4
        rm -rf /data/.apps/linux-3.0.101-0.46
        # Cleanup VirtualBox directory
        cd /data/VirtualBox
        rm ReadyNASOS_V6.2.3_WW_src.zip
        rm Oracle_VM_VirtualBox_Extension_Pack-4.3.26-98988.vbox-extpack
        rm VBoxGuestAdditions_4.3.26.iso
        rm virtualbox-4.3_4.3.26-98988~Debian~wheezy_amd64.deb
        rm -rf tmp ## This should only be the extracted version of ReadyNASOS_V6.2.3_WW_src.zip
        ## Extract and copy kernel files
        mkdir tmp
        mv ReadyNASOS_V6.4.2_WW_src.zip tmp
        cd tmp
        unzip ReadyNASOS_V6.4.2_WW_src.zip
        cp -rp linux-4.1.16-x86_64/ /data/.apps
        ln -s /data/.apps/linux-4.1.16-x86_64 /usr/src/linux-4.1.16-x86_64
        ## Installation kernel files
        apt-get update
    ** apt-get install build-essential ** You should be able to skip this step but I did it out of habit
        export KERN_DIR=/usr/src/linux-4.1.16-x86_64
        cd /usr/src/linux-4.1.16-x86_64
        cp /data/VirtualBox/tmp/linux-4.1.16-x86_64/arch/x86/configs/defconfig.x86 /usr/src/linux-4.1.16-x86_64/.config
        ## ** Check kernel install options and modules
        apt-get install bc
        make menuconfig
        make ARCH=x86_64
        make modules_install ARCH=x86_64
        ## Uninstall VirtualBox 4.3
        dpkg -r virtualbox-4.3
        ## Install VirtualBox 5.0.16
        dpkg -i virtualbox-5.0_5.0.16-105871-Debian-wheezy_amd64.deb
        sudo /sbin/rcvboxdrv setup
        VBoxManage extpack uninstall "Oracle VM VirtualBox Extension Pack"
        VBoxManage extpack install Oracle_VM_VirtualBox_Extension_Pack-5.0.16.vbox-extpack
    • ChiffaNe's avatar
      ChiffaNe
      Tutor
      Followed the updated procedure and it seems everything actually worked!
      sudo /sbin/rcvboxdrv setup - failed as sudo was not found but I'm not sure it actually is needed, dpkg seems to have installed everything.
      • ChiffaNe's avatar
        ChiffaNe
        Tutor
        Ok, spend the whole afternoon trying to make it work and failing.
        It seems to start and work in the background, but when I try to connect via phpvirtualbox it fails, says access denied. I created the user vbox and made him a home directory, added to groub vboxusers and edited the /etc/default/virtualbox to run under him.
        Also, interestingly, I can't find the /etc/init.d/vboxweb-service all of the internet is referring to.
ProSupport for Business
