emeijers
Oct 19, 2013Aspirant
VPN wrong object downloaded
On the ReadyNAS 102 i have installed from the VPN Server 1.1.9 from Poussin via menu apps. Downloaded = softether-vpnserver_vpnbridge-v1.00-9371-rtm-2013.07.25-windows-x86_x64-intel.exe. That is the ...
super_poussin
Oct 24, 2013Virtuoso
You must install the deb file on your NAS
The exe file is provided to help you set up the vpn server from a windows PC ( only install the console part)
