marco_qwerty_88
May 29, 2016Aspirant
webdav interface broken
Hello, I've installed the owncloud app from the list of available apps for my ReadyNAS 104 running the firmware 6.5.0. I would like my server to keep my documents and automatically syncronize th...
BrianL2
May 31, 2016NETGEAR Employee Retired
Hi marco_qwerty_88,
Welcome to the community!
Since no one has experienced this error when installing the said add-on, let's ask the developer himself WhoCares_ super_poussin for some input.
Kind regards,
BrianL
NETGEAR Community Team
WhoCares_
May 31, 2016Mentor
If I recall correctly this messages stems from a faulty test for a working WebDAV connection in older versions of ownCloud. I believe I fixed it somehow back then but I totally forgot how since newer versions don't seem to have that problem - at least I don't apply any specific patch to my version of ownCloud 9.
-Stefan
- marco_qwerty_88Jun 06, 2016Aspirant
Hello,
many thanks for these answers.
So I should probably just Install owncloud 9 then. However this is not listed among the avalaible apps for installation in the netgear interface. I'm sure somewhere it is explained how to install the app anyway. As soon as I figure this out I'll give a try to owncloud 9 and I will let you know how it goes.
Many thanks again for your help
- marco_qwerty_88Jul 09, 2016Aspirant
hello,
I finally found some time to work on this.
When I upload the .deb file to install the owncloud 9 I get the error message : cannot install application owncloud_9.0.2-rnx1_all.deb
I looked for this error in the forum but it seems that nobody gets this...
Does anybody have a clue about how I should procede?
Many thanks again for the great help!
- WhoCares_Jul 09, 2016Mentor
Anything in /var/log/readynasd/install_debpkg.log that could provide some hints?
-Stefan
