marco_qwerty_88
May 29, 2016Aspirant
webdav interface broken
Hello, I've installed the owncloud app from the list of available apps for my ReadyNAS 104 running the firmware 6.5.0. I would like my server to keep my documents and automatically syncronize th...
WhoCares_
May 31, 2016Mentor
If I recall correctly this messages stems from a faulty test for a working WebDAV connection in older versions of ownCloud. I believe I fixed it somehow back then but I totally forgot how since newer versions don't seem to have that problem - at least I don't apply any specific patch to my version of ownCloud 9.
-Stefan
marco_qwerty_88
Jun 06, 2016Aspirant
Hello,
many thanks for these answers.
So I should probably just Install owncloud 9 then. However this is not listed among the avalaible apps for installation in the netgear interface. I'm sure somewhere it is explained how to install the app anyway. As soon as I figure this out I'll give a try to owncloud 9 and I will let you know how it goes.
Many thanks again for your help
- marco_qwerty_88Jul 09, 2016Aspirant
hello,
I finally found some time to work on this.
When I upload the .deb file to install the owncloud 9 I get the error message : cannot install application owncloud_9.0.2-rnx1_all.deb
I looked for this error in the forum but it seems that nobody gets this...
Does anybody have a clue about how I should procede?
Many thanks again for the great help!
- WhoCares_Jul 09, 2016Mentor
Anything in /var/log/readynasd/install_debpkg.log that could provide some hints?
-Stefan
I paste the log below. I admit that it goes beyond my understanding...
START(/tmp/owncloud_9.0.2-rnx1_all.deb): Sat Jul 9 17:30:06 CEST 2016 Hit http://egnyte-cdn.egnyte.com 6.5 InRelease Hit http://security.debian.org wheezy/updates InRelease Hit http://egnyte-cdn.egnyte.com 6.5/egnyte armel Packages Hit http://egnyte-cdn.egnyte.com 6.5/egnyte armhf Packages Ign http://apt.readynas.com 6.5.1 InRelease Hit http://security.debian.org wheezy/updates/main armel Packages Hit http://security.debian.org wheezy/updates/main armhf Packages Ign http://mirrors.kernel.org wheezy InRelease Hit http://mirrors.kernel.org wheezy Release.gpg Hit http://apt.readynas.com 6.5.1 Release.gpg Hit http://mirrors.kernel.org wheezy Release Hit http://apt.readynas.com 6.5.1 Release Hit http://mirrors.kernel.org wheezy/main armel Packages Hit http://apt.readynas.com 6.5.1/updates armel Packages Hit http://mirrors.kernel.org wheezy/main armhf Packages Hit http://apt.readynas.com 6.5.1/apps armel Packages Hit http://apt.readynas.com 6.5.1/main armel Packages Hit http://apt.readynas.com 6.5.1/updates armhf Packages Hit http://apt.readynas.com 6.5.1/apps armhf Packages Hit http://apt.readynas.com 6.5.1/main armhf Packages Reading package lists... new debian package, version 2.0. size 28608372 bytes: control archive=288499 bytes. 684 bytes, 15 lines control 1068066 bytes, 10764 lines md5sums 2752 bytes, 102 lines * postinst #!/bin/bash 1147 bytes, 40 lines * postrm #!/bin/sh 452 bytes, 23 lines * preinst #!/bin/sh Package: owncloud Version: 9.0.2-rnx1 Architecture: all Maintainer: ReadyNAS Xtras <xtras@readynasxtras.com> Installed-Size: 81166 Depends: apache2, php5, php5-sqlite, php5-common, php5-gd, php5-xcache, php-xml-parser, php5-imagick, php5-intl, php5-mcrypt, php5-curl, ntpdate Depends: apache2, php5, php5-sqlite, php5-common, php5-gd, php5-xcache, php-xml-parser, php5-imagick, php5-intl, php5-mcrypt, php5-curl, ntpdate Found 12 dependants pkg[1/12]= apache2 pkg[2/12]= php5 pkg[3/12]= php5-sqlite pkg[4/12]= php5-common pkg[5/12]= php5-gd pkg[6/12]= php5-xcache pkg[7/12]= php-xml-parser pkg[8/12]= php5-imagick pkg[9/12]= php5-intl pkg[10/12]= php5-mcrypt pkg[11/12]= php5-curl pkg[12/12]= ntpdate Chking dependencies.. pkg[1/12]= apache2 Depenency apache2 met pkg[2/12]= php5 Depenency php5 met pkg[3/12]= php5-sqlite Depenency php5-sqlite met pkg[4/12]= php5-common Depenency php5-common met pkg[5/12]= php5-gd Depenency php5-gd met pkg[6/12]= php5-xcache Depenency php5-xcache met pkg[7/12]= php-xml-parser Depenency php-xml-parser met pkg[8/12]= php5-imagick Depenency php5-imagick met pkg[9/12]= php5-intl Depenency php5-intl met pkg[10/12]= php5-mcrypt Depenency php5-mcrypt met pkg[11/12]= php5-curl Depenency php5-curl met pkg[12/12]= ntpdate Depenency ntpdate met Section: devel Priority: optional Description: ownCloud Server - Private file sync and share server ownCloud Server provides you a private file sync and share cloud. Host this server to easily sync business or private documents across all your devices, and share those documents with other users of your ownCloud server on their devices. . ownCloud - Your Cloud, Your Data, Your Way! www.owncloud.org fv-dpkginstall.awk: success Successfully installed dependencies for /tmp/owncloud_9.0.2-rnx1_all.deb (Reading database ... 26928 files and directories currently installed.) Preparing to replace owncloud 6.0.0 (using .../owncloud_9.0.2-rnx1_all.deb) ... Cannot find <add-s>, but found <error-code> dpkg: error processing /tmp/owncloud_9.0.2-rnx1_all.deb (--install): subprocess new pre-installation script returned error exit status 1 Errors were encountered while processing: /tmp/owncloud_9.0.2-rnx1_all.deb (Reading database ... 26928 files and directories currently installed.) Preparing to replace owncloud 6.0.0 (using .../owncloud_9.0.2-rnx1_all.deb) ... Cannot find <add-s>, but found <error-code> dpkg: error processing /tmp/owncloud_9.0.2-rnx1_all.deb (--install): subprocess new pre-installation script returned error exit status 1 Errors were encountered while processing: /tmp/owncloud_9.0.2-rnx1_all.deb DONE(5): Sat Jul 9 17:30:53 CEST 2016 spooler returns spool_status=5 outbuf=(null) errbuf=(null) is_localapp=1 name=owncloud_9.0.2-rnx1_all.deb pkgname=owncloud Reading package lists... Building dependency tree... Reading state information... Package 'owncloud' is not installed, so not removed 0 upgraded, 0 newly installed, 0 to remove and 22 not upgraded. Success purge owncloud DONE(0): Sat Jul 9 17:32:02 CEST 2016 START(/tmp/owncloud_9.0.2-rnx1_all.deb): Sat Jul 9 17:32:23 CEST 2016 Hit http://egnyte-cdn.egnyte.com 6.5 InRelease Ign http://apt.readynas.com 6.5.1 InRelease Hit http://security.debian.org wheezy/updates InRelease Hit http://egnyte-cdn.egnyte.com 6.5/egnyte armel Packages Hit http://egnyte-cdn.egnyte.com 6.5/egnyte armhf Packages Hit http://security.debian.org wheezy/updates/main armel Packages Hit http://security.debian.org wheezy/updates/main armhf Packages Ign http://mirrors.kernel.org wheezy InRelease Hit http://mirrors.kernel.org wheezy Release.gpg Hit http://apt.readynas.com 6.5.1 Release.gpg Hit http://mirrors.kernel.org wheezy Release Hit http://apt.readynas.com 6.5.1 Release Hit http://mirrors.kernel.org wheezy/main armel Packages Hit http://mirrors.kernel.org wheezy/main armhf Packages Hit http://apt.readynas.com 6.5.1/updates armel Packages Hit http://apt.readynas.com 6.5.1/apps armel Packages Hit http://apt.readynas.com 6.5.1/main armel Packages Hit http://apt.readynas.com 6.5.1/updates armhf Packages Hit http://apt.readynas.com 6.5.1/apps armhf Packages Hit http://apt.readynas.com 6.5.1/main armhf Packages Reading package lists... new debian package, version 2.0. size 28608372 bytes: control archive=288499 bytes. 684 bytes, 15 lines control 1068066 bytes, 10764 lines md5sums 2752 bytes, 102 lines * postinst #!/bin/bash 1147 bytes, 40 lines * postrm #!/bin/sh 452 bytes, 23 lines * preinst #!/bin/sh Package: owncloud Version: 9.0.2-rnx1 Architecture: all Maintainer: ReadyNAS Xtras <xtras@readynasxtras.com> Installed-Size: 81166 Depends: apache2, php5, php5-sqlite, php5-common, php5-gd, php5-xcache, php-xml-parser, php5-imagick, php5-intl, php5-mcrypt, php5-curl, ntpdate Depends: apache2, php5, php5-sqlite, php5-common, php5-gd, php5-xcache, php-xml-parser, php5-imagick, php5-intl, php5-mcrypt, php5-curl, ntpdate Found 12 dependants pkg[1/12]= apache2 pkg[2/12]= php5 pkg[3/12]= php5-sqlite pkg[4/12]= php5-common pkg[5/12]= php5-gd pkg[6/12]= php5-xcache pkg[7/12]= php-xml-parser pkg[8/12]= php5-imagick pkg[9/12]= php5-intl pkg[10/12]= php5-mcrypt pkg[11/12]= php5-curl pkg[12/12]= ntpdate Chking dependencies.. pkg[1/12]= apache2 Depenency apache2 met pkg[2/12]= php5 Depenency php5 met pkg[3/12]= php5-sqlite Depenency php5-sqlite met pkg[4/12]= php5-common Depenency php5-common met pkg[5/12]= php5-gd Depenency php5-gd met pkg[6/12]= php5-xcache Depenency php5-xcache met pkg[7/12]= php-xml-parser Depenency php-xml-parser met pkg[8/12]= php5-imagick Depenency php5-imagick met pkg[9/12]= php5-intl Depenency php5-intl met pkg[10/12]= php5-mcrypt Depenency php5-mcrypt met pkg[11/12]= php5-curl Depenency php5-curl met pkg[12/12]= ntpdate Depenency ntpdate met Section: devel Priority: optional Description: ownCloud Server - Private file sync and share server ownCloud Server provides you a private file sync and share cloud. Host this server to easily sync business or private documents across all your devices, and share those documents with other users of your ownCloud server on their devices. . ownCloud - Your Cloud, Your Data, Your Way! www.owncloud.org fv-dpkginstall.awk: success Successfully installed dependencies for /tmp/owncloud_9.0.2-rnx1_all.deb Selecting previously unselected package owncloud. (Reading database ... 15854 files and directories currently installed.) Unpacking owncloud (from .../owncloud_9.0.2-rnx1_all.deb) ... Cannot find <add-s>, but found <error-code> dpkg: error processing /tmp/owncloud_9.0.2-rnx1_all.deb (--install): subprocess new pre-installation script returned error exit status 1 Errors were encountered while processing: /tmp/owncloud_9.0.2-rnx1_all.deb (Reading database ... 15854 files and directories currently installed.) Unpacking owncloud (from .../owncloud_9.0.2-rnx1_all.deb) ... Cannot find <add-s>, but found <error-code> dpkg: error processing /tmp/owncloud_9.0.2-rnx1_all.deb (--install): subprocess new pre-installation script returned error exit status 1 Errors were encountered while processing: /tmp/owncloud_9.0.2-rnx1_all.deb DONE(5): Sat Jul 9 17:32:58 CEST 2016 spooler returns spool_status=5 outbuf=(null) errbuf=(null) is_localapp=1 name=owncloud_9.0.2-rnx1_all.deb pkgname=owncloud
