BulletRouge
Feb 10, 2018Aspirant
What are folks using for Dynamic DNS (no-ip) client?
Running current OS 6 What are folks using for Dynamic DNS? I have my account on no-ip but having difficulty finding a client I can run on my NAS.
givememynamebak
May 07, 2018Luminary
Try DNSOMatic. It supports more than one "client" and registrar. You can have them all sync together or not... I use it in my Asus Router DDNS update. You shouldn't have to run it on your NAS but you can as a script if you prefer. Router config should be easier as I think it's a standard feature these days in modern routers. Then as the post above indicates, use port forwarding to your NAS. There's some DNSOMatic plugins too I believe... see: https://community.netgear.com/t5/Community-Add-ons/DnsOmatic/td-p/675811
