NASguru
Oct 28, 2016Apprentice
Which Photo database are most using: Piwigo or Koken? Why?
So I'm looking to migrate off Photos II and to either Piwigo or Koken. I'm leaning towards Piwigo since I saw some older posts about Koken possibly going away. Either way, I like to hear from other...
NASguru
Nov 01, 2016Apprentice
Sandshark wrote:
NASguru wrote:Bummer and too bad you don't have a link to their forum on what files were actually edited.
I was "Sandshark" there as well, so try a search. See also PM from me.
Will do and I have replied to your PM. Other than the DDNS issue, did you like Piwigo or moved onto something else? Did you install it from the Readynas App store as the version there seems old? I also use DDNS via NO IP so it will likely be an issue for me too if the fix was not carried through. I found your post on their forum on the email link issue: http://piwigo.org/forum/viewtopic.php?id=25791
It's sort of disappointing that you made that post over a year ago and that this may still be an issue.
Sandshark
Nov 04, 2016Sensei
I was running it for a group and the group disbanded, so I had no use for it any longer. I originally installed the App, then updated it from within Piwigo. I had no issues with installing updates or add-ons directly.
- NASguruNov 04, 2016Apprentice
Sandshark wrote:I was running it for a group and the group disbanded, so I had no use for it any longer. I originally installed the App, then updated it from within Piwigo. I had no issues with installing updates or add-ons directly.
That's good to know so it would seem if I get it up and running properly that I should be able to keep it going via their updates. The ONLY issue I can forsee is future updates of the Readynas firmware unless a developer takes ownership of it and keeps it current. I appreciate the feedback either way!
- Aug 18, 2018Retired_Member
