gaetan
Jan 27, 2012Aspirant
-16443401 Mo (-3565%) of 450 Go used
Hi, My RedyNas NVX is reporting funny figures regarding disk space. Both 500 GB disks (X-RAID2) - no errors reported. Model: ReadyNAS NVX Business Edition [X-RAID2] Firmware: RAIDiator 4.2.19 ...
gaetan
Jan 28, 2012Aspirant
Ok, rebooting and scanning seems to have sorted the issue.
***** File system check performed at Sat Jan 28 10:02:18 WET 2012 *****
fsck 1.41.14 (22-Dec-2010)
e2fsck 1.41.14 (22-Dec-2010)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/c/c: 262386/7393280 files (32.4% non-contiguous), 85615484/118292480 blocks
Volume C: Online, X-RAID2, 2 disks, 72% of 450 GB used
Many thanks for the suggestion.
May I ask another quick question ?
At the moment, I have 2 disk of 500 Go ...
Can you please confirm that if I want to expand the storage space, I have 2 solutions:
1- addind a third (or fourth, fifth ..) hard drive of the same capacity in order to expand storage space.
or
2- remove one of the 2 500Go disks - then add for exemple a 1To hd, wait for data to be copied ... reboot ReadyNas in order to expand free space, then replace the other 500Go disk leave by another one of 1To
Thanks
Gaëtan
or
Thanks
Gaëtan
