mikeywetzel
Sep 10, 2016Tutor
.NET Core on ReadyNAS 6.5.1
My real question is: has anyone succeeded in hosting a asp.net website from their ReadyNAS? There's alot of information on the web that says this is not possible, but I believe that info is out of da...
wizard
Sep 10, 2016Aspirant
If it's SSH information then the username should be root and port is 22.
- mikeywetzelSep 10, 2016Tutor
I managed to get into the SSH using PuTTY from a PC. Once there, it didn't know what "sudo" was so, I found instructions online to install that.
I'm at the first step, but it gives an error that "unable to locate package libunwind8". This seems like a common problem mentioned on various forums, but I've yet to be able to get past this step.
Mikey
- mdgm-ntgrSep 11, 2016NETGEAR Employee Retired
If you are already logged in as root then using sudo to run commands as if you were root is pointless as you are logged in as the root user already.
