aalexandrebeta's avatar
Jun 25, 2016
Readynas 316 6.5.1 fan threshold below speed
6.5.0 was great for that matter.
6.5.1 turned a good new feature into a mess can't go up to 800 rpm!
URGENT FIX IS NEEDED HOT SUMMER TIME  her without AC!
  • BrianL2's avatar
    BrianL2
    Jul 06, 2016
    Hi aalexandrebeta,
    Thanks for the feedback. You may update this thread if the problem persist or if you get other suggestions from support.
    Kind regards,
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello aalexandrebeta,
    Please contact support center to report this, you have lifetime CHAT support for your ReadyNAS 316.
  • JennC's avatar
    JennC
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    • I don't know what happened but after 2 days where the NAS didn't work properly, the fan speed seems to be OK now!
      I sent a request to the support.
      Thanks.
      • BrianL2's avatar
        BrianL2
        Hi aalexandrebeta,
        Kind regards,
ProSupport for Business
