d_ux
Sep 03, 2021Aspirant
100060 Big Sur Dropping Connection
Seeing the ReadyNAS 424 drop Mac connection when moving large folders across. Stopping at various points - for 180GB has stopped at 3GB/12GB/32GB/60GB - no obvious pattern. This is on Big Sur. ...
d_ux
Uploading locally via Finder. Have SMB sharing set up.
Also have Time Machine enabled. Just watching the large backups to see if there are any connection drops when backing up.
realmcoy
Sep 04, 2021Aspirant
Check your network config .. restart your swich and dhcp server check for dupicate IP addrsess. bad cables etc.
