the11
Oct 14, 2014Aspirant
104 support for 6TB hdds and Fan Replacement question
Hi there, I think about buying a ReadyNAS 104 but there are two things that I have to get clear first (burned child). 1.) I wait for a firmware that supports 6TB HDDs because I have a lot of big...
the11
Hi and Thanks for your response!
Is this technically impossible or could that get pushed in a future firmware?
Let me guess, the guarantee does NOT cover the (wearing part) fan (and its silent operation) for the 3 to 5 years, right?
Let me guess again if my 104 fan stopps operation or becomes annoying loud in the 31st month, Netgear will Not change it on guarantee base, right?
Exactly that is my question. On which circumstances should the NAS accept or deny a different fan? What is this depending on?
Manufacturer? Voltage? rpm Speed? All of it?
mdgm wrote: 1) The 104 does not support volumes larger than 16TB in capacity.
mdgm wrote: 2) Replacing the fan does void the warranty. The 104 has a 3 year limited hardware warranty and the 314 has a 5 year limited hardware warranty.
mdgm wrote: Depending on what fan you choose the NAS may think it has a problem.
