the11
Oct 14, 2014Aspirant
104 support for 6TB hdds and Fan Replacement question
Hi there,
I think about buying a ReadyNAS 104 but there are two things that I have to get clear first (burned child).
1.) I wait for a firmware that supports 6TB HDDs because I have a lot of big files to store (filming the kiddies consumes space faster as light...)
now comes the really serious part
2.) I already own a Synology 411+II and I have the widely spread Synology-problem with replacement fans.
(fans got louder in lifetime, replacement with fitting silent fans now gets me an false alarm that a fan would not work (i checked it does!), raises a error log entry, after a minute it logges the fan would have continue working ...till the next minutes)
I can turn off fhe annoying beeping BUT the NAS is no more getting to sleep now because it is running in (false) error mode!
The long discussions in the forum came to the conclusion that Synology uses a non-standard fan signal management of the fan pins. So EVERY non-original fan would cause this error. (means you're bound for all times to one manufacturer which you CANNOT buy simply in the internet from as a normal consumer customer) :twisted:
http://forum.synology.com/enu/viewtopic.php?f=140&t=28534&start=15#p239802
so
Question 1)
How fast come the firmwares usually to the non-business ReadyNAS models? Is the 104 even Expected to support 6TB HDDs in time (or later 8, 10, 15 TB hdds) or is this model already dead for future support an I have to buy a 314 (much more expensive)?
Question 2)
Does Netgear models like 104 allow simple fan replacement with user standard fans from different manufacturers or is there such a hidden gyve too like the one Synology "surprises" its customers with?
Many thanks in advance!
so
Question 1)
Question 2)
- mdgm-ntgrNETGEAR Employee RetiredYou should try to keep your NAS in an environment where there hopefully won't be too big a build up of dust.
- the11Aspirant
mdgm wrote: You should try to keep your NAS in an environment where there hopefully won't be too big a build up of dust.
Sure but wear is not only a matter of dust. ;-)
