apeofjungle
Aug 01, 2011Aspirant
16tb Limit - Is that Useable or Total?
Hi, I notice X-RAID isn't expandable beyond 16tb. But is that useable space, or the total? So for example (using rounded numbers) if I have the Pro 6 in X-RAID with single redundancy with 5x3tb=...
apeofjungle
From that link
Cool. To be honest, I think it will be a long time before I hit that wall. I'm not a big data horder. Hopefully it will be sorted by then.
When I first set up the Pro, is there anything special I need to do mixing the drives that are over and under the 2gb old limit?
yoh-dah wrote: It's a limitation with the Ext4 expansion utility and we're working to get rid of that limitation. But with anything related to filesystem, we have to take extreme caution so I can't give any estimate of when we would be able to get that fixed.
