TWilson
Oct 28, 2022Aspirant
1GB network adapters not working in ReadyNAS 626X (RN626X00)
I appears that both 1GB LAN ports on my ReadyNAS rn626x has failed. The two 10GBe LAN ports are working ok. When I power on the NAS with no patch cables attached; the 1GB LAN2 port link LED imme...
TWilson
Oct 29, 2022Aspirant
I was thinking the same thing. I already reset it to factory defaults with a new uninitialized disk installed and got the same results.
I'll contact paid support to see what can be done and at what cost. I bought this one used so I don't have warranty. If its not economical to repair, I continue running it as is since I don't use the 1GB LAN ports anyways.
Since Netgear EOL'd the ReadyNAS line, I need to migrate away from them anyways. I've had a good run with them for the past 14 or so years. Still have a couple RNDP6000 reliably running 24x7 in production (with upgraded RAM, CPU and OS6).
I'm considering moving to TrueNAS Mini XL+ running Scale to enable replication (once Scale is production worthy).
Sandshark
Oct 29, 2022Sensei
Netgear won't repair it, so save your money. They've never offered in or out of warranty repairs on ReadyNAS -- just warranty replacement.
