Ejik2
May 07, 2025Aspirant
2.5GBe USB LAN
I have an old Ultra2 2Gb RAM running 6.10.9 OS. NAS is working great but 1Gb LAN is a bottleneck. I've bought cheap 2.5GBe USB LAN adapter based on realtek chip, attached to USB3 port and installed ...
ddewrbbdg
Jan 21, 2026Guide
Hi, could you explain how to proccess whole driver installation? You are talking regarding driver compilation.
There is package you refer to (R8152 package - oficial website driver) and something called DKMS.. last time i tried DKMS (from github project), installed appeared correctly, but no new ethernet adapter appeared. Currently uptodate version is both 2.21.4
Im noob in this.. modding old outdated linux, like mobs like to say. :-) I have bought cheap RTL8157 5gbe adapter from CableMatters at ebay recently. Connected to the only usb 3.1 at RN312 unit. It appears in usb listed devices, etc. I dont expect miracle, but network transfers speed improvement would be better. This topic gave me hope.
I would add lsusb and other commands info, but currently, just for sure, reinstalling and defaulting whole RNOS after last fail.
- Ejik2Jan 22, 2026Aspirant
1) Get hold of the NETGEAR GPL sources for your firmware version from here: https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL
2) Unpack the file on the ReadyNAS (ideally you'll use the root account for that but preferrably NOT the root home directory. Some directory below /data will be fine
3) Copy the linux-kernel-* source directory for your architecture from the unpacked GPL archive to another place, say /data/kernel
4) Go to that directory and run "make clean && make && make install && make modules_install" (the last one is optional)
5) Create a symlink from the directory to /lib/modules/<your kernel version>
6) Extract the driver, than from the extracted data directory run make; make install
