Retired_Member
Mar 04, 20142.5TB with ReadyNAS Duo ?
I own the ReadyNAS duo version that doesn't support HDD above 2TB My question is : can i use a 2.5TB in this unit and get 2TB of storage space ? I don't expect to get above 2TB capacity but will my...
Mar 04, 2014Guru - Experienced User
If you just install the drive, it will detect much less space than 2 TB. I don't know the amount for 2.5TB drives, but for 3 TB drives it detects something like ~700 GB.
You are better off just getting another 2 TB drive.
