Retired_Member
Mar 04, 20142.5TB with ReadyNAS Duo ?
I own the ReadyNAS duo version that doesn't support HDD above 2TB My question is : can i use a 2.5TB in this unit and get 2TB of storage space ? I don't expect to get above 2TB capacity but will my...
Retired_Member
Mar 04, 2014Oh i see... it's not worth it then.
I have another ReadyNas Pro with 4x 2TB.... Can i just replace one of the HDD by my 2.5TB, then take the 2TB from it and put it in my ReadyNAS Duo ? Or will it mess the Pro device because there will be 3x 2TB and 1x 2.5TB ?
