boblam
Apr 21, 2012Aspirant
2 TB Drives Supported Ultra 4 Plus - High Speed
I am interested in the ReadyNAS Ultra 4 Plus, but most that I find are diskless. What is a fast 2 GB drive that will work with this device? For example, it looks like most sites have: Seagate B...
Apr 21, 2012Guru - Experienced User
Not really. The 3 GB/s SATA speed is much faster than the raw drive speed. The reason for the higher price is that these are enterprise (server) class drives, not desktop drives.
boblam wrote: It looks like the one that I have seen in the performance testing is (but cost substantially more) is:
Seagate Constellation ES 2 TB 7200 RPM SATA 3 GB/s 64 MB Cache 3.5-Inch Hard Drive - ST32000644NS ($290)
but it would seem like this should be slower based on 3 GB/s
I think you found them. Green drives will be somewhat slower than the 7200 rpm drives (10% is a number frequently cited here). Also check the HCL, since Netgear support is limited if get drives that are not on their list.
boblam wrote: Any thoughts on a fast 2 TB drive that works with Ultra 4 Plus?
Someplace that will let you exchange them in a 30 day window for new drives if one fails. Amazon or Newegg both have this policy. Manufacturer replacements are refurbished, so it is best to have a retailer that has a good replacement policy.
boblam wrote: Any advice on where to purchase this device / drives?
What are you confused about? iSCSI is a product feature.
boblam wrote: I'm also confused as to why most vendors sell this as part # RNDP400U-100NAS and then reference iSCSI.
