boblam
Apr 21, 2012Aspirant
2 TB Drives Supported Ultra 4 Plus - High Speed
I am interested in the ReadyNAS Ultra 4 Plus, but most that I find are diskless. What is a fast 2 GB drive that will work with this device? For example, it looks like most sites have: Seagate B...
boblam
Thanks for the feedback.
My only confusion on the iSCSI part is that when I look at purchasing the device, there is typically a model number like:
RNDP400U-100NAS
Wasn't sure if the suffix (100NAS) really meant something or just an adder to the base part number for vendor identification. I wanted to make sure I didn't need different drives or the device had different features based on the suffix.
I'm thinking about the Seagate Barracuda ST2000DM001 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive ($120)
It looks like people have had success using it on the community hardware list (viewtopic.php?f=83&t=58882). The actual HCL looks pretty limited and almost impossible to purchase drives from (http://www.readynas.com/?page_id=82).
Anyone have an issue with this drive?
RNDP400U-100NAS
