KILLI
Jan 26, 2015Tutor
2100: 4TB and larger Disks possible?
Hi! Is it possible to use 4TB or even larger Disks in a ReadyNAS 2100v1? The official HCL only extends up to 3TB, but then probably Netgear has stopped testing newer and bigger HDDs for older unit...
mdgm-ntgr
Jan 26, 2015NETGEAR Employee Retired
In the 2100v1 the maximum volume capacity would be 16TB. 4TB disks should work.
