Ouija
Nov 03, 2016Aspirant
214 nothing but problems trying to setup and install Plex
I seriously am not this "computer stupid" so either this unit is the demon spawn from hell, or this is a horrible product! Perhaps this information below will help someone else, possibly help me diag...
- Nov 04, 2016Well, no luck on a replacement 214, but since it was bad hardware Fry's happily took back the 214 and the 3x3TB drives. Sorry to Netgear but due to the bad taste I got from the 214, for only $60 more I walked out with a Western Digital MyCloud PR4100 that had the new Intel processor and 4x2TB Red drives all preinstalled that supposedly can also easily run Plex and transcode.
Nov 03, 2016Guru - Experienced User
Ouija wrote:
The box claims it had v6.4.1 but was a version 5.4.x when it powered up
Something really strange here. The RN214 never shipped with 5.x firmware, that is only for the legacy NV+ v2 and Duo v2. There has never been a ReadyNAS 5.4.x release.
You need to get the plex server directly from https://www.plex.tv/downloads/ Select Netgear as the platform, then "Arm 6.x RN2xx" You use the upload control on the apps page to install it.
- OuijaNov 03, 2016Aspirant
Unfortunately that is exactly where I downloaded the software from most recently however I will happily attempt it again and will let you know.
Again, I appreciate your input in my time of frustration! :-)
I cleared my logs prior to attempting to install again via the "Upload" option, now there is one line item in the logs:
Thu Nov 3 2016 15:05:29 System: Cannot install application plexmediaserver-ros6-binaries-annapurna_1.2.5.2966-3f767e7_armel.deb. If I go to Apps it states Plex Media Server (for RN2xx) is installed. Version 1.2.5.2966-3f767e7
I switched the switch to ON
but I still get a Website can't be reached when it tries to go to 192.168.1.204:3200/web
Doesn't matter if I'm in Chrome or Edge on my Windows 10 box, nor does it work from Chrome or Safari on my Macbook Pro.
I can sucesfully hit the ReadyNas Admin page from all my devices, even my iPhone and my Android tablet, but no Plex.
I even soft power cycled the device since it again wouldnt' turn off by pressing the power button 3 times.
I'm seriously begenning to think this is another case of Fry's selling you a "new" in box item that actually was defective and previously used.
- mdgm-ntgrNov 04, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
