MrCyberdude
Apr 15, 2010Guide
2TB WD20EARS HCL Advanced Format 4k Sectors TLER LCC WDidle3
EDIT: This thread was written before the Readynas group had recognized and addressed the WD Advanced Format HDD's. An issue that remains to this day is the massive LCC(Load Cycle Count) increases due ...
MrCyberdude
May 09, 2010Guide
After installing this add-on HDD internal benchmark - debug - test - CIFS - NFS add-on found here in its first release for the x86 versions http://www.readynas.com/contributed/super-poussin/PRO-Bonnie_1.1.bin
I also think I need DD results for each individual HDD, to help pin down a single drive or highlight that its all of them.
Can someone else who has these HDD's please give this add-on a try. The add-on does not require any changes to SSH.
After it has finished running.... Maybe 1hr unit the Status Log states the Speed and test completed.
The results will be in a folder called benchmark in the ReadyNasPro which can be accessed via command prompt running of
Once you have copied the benchmark folder out to desktop remember to right click on P: drive and Disconnect the Mapped network Drive.
This test apeared to take much longer (1 hour) than it should of and I personally believe it is due to the 4k cluster overlap issues with Advanced Format.
Version 1.96 ------Sequential Output------ --Sequential Input- --Random-Mon May 10 02:51:10 EST 2010 HardDisk Test Results are available !.
-Per Chr- --Block-- -Rewrite- -Per Chr- --Block-- --Seeks--
Machine Size K/sec %CP K/sec %CP K/sec %CP K/sec %CP K/sec %CP /sec %CP
ReadyNasPro 2G 760 88 20656 4 17189 4 734 55 147995 26 218.3 3
Latency 9958us 2174ms 1951ms 1518ms 101ms 100ms
------Sequential Create------ --------Random Create--------
-Create-- --Read--- -Delete-- -Create-- --Read--- -Delete--
files:max:min /sec %CP /sec %CP /sec %CP /sec %CP /sec %CP /sec %CP
ReadyNasPro 256 239 99 302797 99 21390 19 259 99 314931 99 325 49
Latency 406ms 664us 432us 444ms 60us 4932ms
Mon May 10 02:51:10 EST 2010 DD Result:91.5MB/s
Mon May 10 02:51:10 EST 2010 DD Result...
Mon May 10 02:49:26 EST 2010 Please Wait...
Mon May 10 02:49:26 EST 2010 DD Test...
Mon May 10 01:55:53 EST 2010 Please Wait...
Mon May 10 01:55:53 EST 2010 Disk Benchmark...
Mon May 10 01:55:51 EST 2010 Bonnie service has been started.
Sun May 9 23:54:32 EST 2010 The Bonnie Add-on has been successfully installed.
===1.96,1.96,ReadyNasPro,1,1273419028,2G,,760,88,20656,4,17189,4,734,55,147995,26,218.3,3,256,,,,,239,99,302797,99,21390,19,259,99,314931,99,325,49,9958us,2174ms,1951ms,1518ms,101ms,100ms,406ms,664us,432us,444ms,60us,4932ms1.96,1.96,ReadyNasPro,1,1273419028,2G,,760,88,20656,4,17189,4,734,55,147995,26,218.3,3,256,,,,,239,99,302797,99,21390,19,259,99,314931,99,325,49,9958us,2174ms,1951ms,1518ms,101ms,100ms,406ms,664us,432us,444ms,60us,4932ms===
4092528+0 records in
4092528+0 records out
2095374336 bytes (2.1 GB) copied, 22.909 seconds, 91.5 MB/s
net use P: \\ip-of-readynas\c /user:adminand then going to P: Drive on My Computer.
