MrCyberdude
Apr 15, 2010Guide
2TB WD20EARS HCL Advanced Format 4k Sectors TLER LCC WDidle3
EDIT: This thread was written before the Readynas group had recognized and addressed the WD Advanced Format HDD's. An issue that remains to this day is the massive LCC(Load Cycle Count) increases due ...
MrCyberdude
May 20, 2010Guide
Found This http://community.wdc.com/t5/Desktop/Green-Caviar-High-Load-Cycle-Cout-after-short-operation-time/m-p/18192/highlight/true#M1113
RE2GP Idle Mode Update Utility
File Name: wdidle3_1_05.zip
File Size: 170 KB
Version: N/A
Publish Date: 4/2010
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3263
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=5357
WDIDLE3 http://support.wdc.com/product/download.asp?groupid=609&sid=113&lang=en refers to the WD Tool
WD Community Manager wrote: Bill_S Posts: 896 Registered: 11-24-2009
Re: Green Caviar: High Load Cycle Count after short operation time Options 04-08-2010 04:03 PM
Sorry, but our agent didn't know that this policy was just changed.
Current WDIDLE3 works with the RE and GP drives listed below.
RE Drives - WD1000FYPS-01ZKB0, WD7500AYPS-01ZKB0, WD7501AYPS-01ZKB0
GP Drives - WD20EADS, WD20EARS, WD15EADS, WD15EARS, WD10EADS, WD10EARS, WD8000AARS, WD7500AADS, WD7500AARS, WD6400AADS, WD6400AARS, WD5000AADS, WD5000AARS
File Size: 170 KB
Version: N/A
WDIDLE3 [/S[<Timer>]] [/D] [/R] [/?]
where:
/S[<Timer>] Set timer, units in seconds. Default=8.0 (8.0 seconds).
Resolution is 0.1 seconds from 0.1 to 12.7 seconds.
Resolution is 30 seconds from 30 seconds to 300000 seconds.
Note, times between 12.8 and 30 seconds will be set to 30 seconds.
/D Disable timer.
/R Report current timer.
/? This help info.
