MrCyberdude
Apr 15, 2010Guide
2TB WD20EARS HCL Advanced Format 4k Sectors TLER LCC WDidle3
EDIT: This thread was written before the Readynas group had recognized and addressed the WD Advanced Format HDD's. An issue that remains to this day is the massive LCC(Load Cycle Count) increases due ...
MrCyberdude
May 14, 2011Guide
Load Cycle Count ---------- 1100346 ************* Now Over 1 Million **************
I Still have some concerns over the LLC (Load/UnLoad Cycle Count). http://en.wikipedia.org/wiki/S.M.A.R.T.
The typical lifetime rating for laptop (2.5-in) hard drives is 300,000 to 600,000 load cycles.
Unfortunatly the spec page from WD state otherwise. http://www.wdc.com/wdproducts/library/S ... 701229.pdf Load/unload cycles 300,000
I have been running firmware versions
RAIDiator-x86 4.2.17 since 20110508.
RAIDiator-x86 4.2.15 since 20101218.
RAIDiator-x86 4.2.13 since 20100923.
RAIDiator-x86 4.2.12 since 20100709.
RAIDiator-x86 4.2.12-T32 since 20100625.
Before this I would have to search the logs.
SMART Information for Disk 6
Model: WDC WD20EARS-00S8B1
Serial: WD-WCAVY2476xxx xxx=privacy
Firmware: 80.00A80
SMART Attribute
Raw Read Error Rate ------- 0
Spin Up Time -------------- 9400
Start Stop Count ---------- 51
Reallocated Sector Count -- 0
Seek Error Rate ----------- 0
Power On Hours ------------ 8807
Spin Retry Count ---------- 0
Calibration Retry Count --- 0
Power Cycle Count --------- 49
Power-Off Retract Count --- 24
Temperature Celsius ------- 39
Reallocated Event Count --- 0
Current Pending Sector ---- 0
Offline Uncorrectable ----- 0
UDMA CRC Error Count ------ 0
Multi Zone Error Rate ----- 0
ATA Error Count ----------- 0
