MrCyberdude
Apr 15, 2010Guide
2TB WD20EARS HCL Advanced Format 4k Sectors TLER LCC WDidle3
EDIT: This thread was written before the Readynas group had recognized and addressed the WD Advanced Format HDD's. An issue that remains to this day is the massive LCC(Load Cycle Count) increases due ...
mdgm-ntgr
Mar 13, 2012NETGEAR Employee Retired
Sounds like a good idea.
I would first suggest you ensure you have an up to date backup.
You need 4.2.16 or later to use 3TB drives (update before adding 3TB drives). Note you can't go direct from firmware newer than 4.2.9 but older than 4.2.16 to 4.2.19 you have to update to 4.2.16 first. This is fixed in 4.2.20. 4.2.20-T40 (http://www.readynas.com/forum/viewtopic.php?f=51&t=57193) is pretty stable and I'd probably go with that.
