adrius42
Jul 19, 2011Aspirant
3 Weeks of trying to Add 4 Disks to NV+
Having enjoyed the NV+ for 2 Weeks with 2 1TB Drives I decided to upgrade to 4 * 2TB Drives That's when things started going wrong! I assumed at the beginning it was me. I have tried both forms of c...
mdgm-ntgr
Jul 19, 2011NETGEAR Employee Retired
You can't check the disks properly when they're in a USB case. Connect the disks to a SATA port on your PC and check them using vendor tools. Please run both long and short tests.
Can you try booting the NAS with just one disk? You may need to do a factory reset using the boot menu: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
Please check what version of RAIDiator is installed on the NAS. If not the latest (currently 4.1.7: http://www.readynas.com/RAIDiator_4_1_7_Notes) please update to that.
What brand and model 2TB disks did you purchase?
