UserBackup
Oct 14, 2011Aspirant
3200 – FrontView will not apply changes
I am having issues with my ReadyNAS 3200 – FrontView will not apply changes. Any help you can provide would be highly appreciated. I have read and seen a few posts on this issue, but I wanted to make...
mdgm-ntgr
Oct 18, 2011NETGEAR Employee Retired
If you have SSH access you can SSH in and do
If the 4GB OS partition is full then there is a problem (e.g. backup job logs not truncated properly). Seeing as you were running a very old firmware version it's highly likely that you encountered a bug that has been addressed by newer firmware, in fact I think I remember there being such an issue a while back.
This info is also found in the logs (Status > Logs > Download all Logs) in disk_usage.log
df -h
