cjmcgee
Jun 10, 2010Tutor
3TB drive compatibility?
I own a ReadyNAS Duo with a pair of 1.5 TB drives. It is starting to get full so I am considering upgrading the drives. I could upgrade to 2TB drives, but that seems like a lot of cost and effort f...
rolski
Jul 19, 2011Aspirant
Default jumper config being - no jumpers ?
And how did you run wdidle3 - can you do that while the disks are installed in the NAS ?
I have a new Ultra4+ with 4 WD30EZRSDTL's and I'm having trouble getting the 4th disk installed successfully....
