falconyt
Dec 18, 2015Aspirant
4 pin din power supply replacement for RN104
Hello,
Recently picked up a used ReadyNAS RN104, the power supply adapter that has come with it doesn't stay in the ReadyNAS unless you really push it in. The ReadyNAS works fine however, I would like to get another power supply. Would a generic 4 pin din power supply with the same power specs work? or Does Netgear do something special with the pin outs on their connector?
Thanks.
Hi falconyt,
Yes, a similar power supply with the same specs would do it. Pins or connector differ where the product was released or being sold.
Kind regards,
BrianL
NETGEAR Community Team
- BrianL2NETGEAR Employee Retired
Hi falconyt,
Kind regards,
BrianL
