lanceorion
Apr 14, 2013Aspirant
4TB compatibility
Another question about hard drives! The official HCL lists Hitachi 3TB and 4TB Ultrastar as compatible with the new (and indeed old) readynas devices - ie the 102/4 etc. Does that mean that the ...
mdgm-ntgr
Apr 14, 2013NETGEAR Employee Retired
It's possible that other drives may work. However so note that NetGear can and will deny support if you use drives that are outside the compatibility list.
