simes_pep
Feb 05, 2014Aspirant
4TB Disks for Ultra 2+
So at present the HCL only lists the Hitachi 7k4000 HUS724040ALE640 as compatible. Now this is the Ultrastar device (HUS) and retails at around £250 a disk? The Ultrastar range is offered with a 5...
simonpepper
Feb 08, 2014Aspirant
Thanks for the pointers - looking at the Seagate NAS 4TB disks, which are currently on Amazon.co.uk for £133.90 each.
Will be buying a pair together, so no mix/match issues.
Heh - why doesn't the HDD manufacturers etc. provide pairs, 4 & 6 'matched sets' from the same manufacturing run with sequential SNs, for NAS usage?
Also ordered a Fractal 'Silent Series' 92mm Fan to replace the OEM item (Delta afb0912hh), which has a rated noise of 38 dB-A (max 41) whereas the Fractal (FD-FAN-SSR2-92) is rated at 12.5 dB-A
I replaced the OEM in my Duo with a 60mm Fractal one and the drop in operating noise was significant, though being much smaller was probably having to work much harder than the 92mm in the Ultra Plus.
