enkrypt3d
Jun 06, 2012Tutor
4TB drives coming out....
will these be compatible with my NVX Pioneer edition? I'm almost out of space on my 4 x 2TB drives... and going to 3TB drives really isn't worth it.... anyone know? Thx!
swamp2
Mar 07, 2014Tutor
StephenB wrote: Shifting off the HCL can/will create issues getting support later - just something to keep in mind.
Sorry no idea what you mean here.
StephenB wrote: You can hot-swap them, though the usual expansion limits apply (no more than 8 TiB growth over the live of the volume, cannot expand over 16 TiB).
So if I began with 2 1TB drives I would max out with 10 TB using 16TB of drives?
Thanks!
