enkrypt3d
Jun 06, 2012Tutor
4TB drives coming out....
will these be compatible with my NVX Pioneer edition? I'm almost out of space on my 4 x 2TB drives... and going to 3TB drives really isn't worth it.... anyone know? Thx!
Mar 08, 2014Guru - Experienced User
Understood. One downside of using them is that you could lose support.
swamp2 wrote:
StephenB wrote: HCL - "hardware compatibility list" http://kb.netgear.com/app/answers/detail/a_id/20641
Note the warning: Be sure to use only drives recommended in the compatibility list, otherwise, NETGEAR Technical Support can and will deny support.
I did look there. No 4 TB drives listed in the HCL for the Pioneer NVX only 3 TB
Download the log files. initrd.log will tell you the time of the initial install/factory reset.
swamp2 wrote: How can I check if I began with 2x1TB? I may have started fresh with 4x1TB since that point in time. Thanks again.
If you search expansion.log for "Extending logical volume c" you will see the various sizes (including the initial install).
